OpenCV's remap() function does it pretty fast. The image in the following example is upside down, but I'll leave fixing that as an exercise for the reader:
from __future__ import division
import os, platform, sys, threading
#Set this to the location of your Leap SDK
LEAP_SDK_PATH = os.path.abspath('/Users/jward/Desktop/LeapSDK')
# Get the correct Leap library directory for platform/bit-depth
current_platform = platform.system()
if current_platform == "Windows":
arch_dir = 'lib/x64' if sys.maxsize > 2**32 else 'lib/x86'
elif current_platform == "Darwin":
arch_dir = 'lib'
elif current_platform == "Linux":
# Add that library to module search path
sys.path.insert(0, os.path.abspath(os.path.join(LEAP_SDK_PATH, arch_dir)))
import cv2, Leap, math
import ctypes
import numpy as np
destinationWidth, destinationHeight = 640, 240
destination = np.empty((destinationWidth, destinationHeight), dtype = np.ubyte)
def initDistortionMap(image):
distortion_length = image.distortion_width * image.distortion_height
xmap = np.zeros(distortion_length/2, dtype=np.float32)
ymap = np.zeros(distortion_length/2, dtype=np.float32)
for i in range(0, distortion_length, 2):
xmap[distortion_length/2 - i/2 - 1] = image.distortion[i] * image.width
ymap[distortion_length/2 - i/2 - 1] = image.distortion[i + 1] * image.height
xmap = np.reshape(xmap, (image.distortion_height, image.distortion_width/2))
ymap = np.reshape(ymap, (image.distortion_height, image.distortion_width/2))
#resize the distortion map to equal desired destination image size
expanded_xmap = cv2.resize(xmap, (image.width, image.height), 0, 0, cv2.INTER_LINEAR)
expanded_ymap = cv2.resize(ymap, (image.width, image.height), 0, 0, cv2.INTER_LINEAR)
return expanded_xmap, expanded_ymap
def interpolate(image, xmap, ymap):
#wrap image data in numpy array
i_address = int(image.data_pointer)
ctype_array_def = ctypes.c_ubyte * image.height * image.width
# as ctypes array
as_ctype_array = ctype_array_def.from_address(i_address)
# as numpy array
as_numpy_array = np.ctypeslib.as_array(as_ctype_array)
img = np.reshape(as_numpy_array, (image.height, image.width))
#remap image to destination
destination = cv2.remap(img, xmap, ymap, interpolation = cv2.INTER_LINEAR)
#to resize output:
#destination = cv2.resize(destination, (destinationWidth, destinationHeight), 0, 0, cv2.INTER_LINEAR)
return destination
def process(controller):
mapInitialized = False
while(True):
frame = controller.frame()
image = frame.images[0]
if image.is_valid:
if not mapInitialized:
left_x_map, left_y_map = initDistortionMap(frame.images[0])
right_x_map, right_y_map = initDistortionMap(frame.images[1])
mapInitialized = True
undistorted_left = interpolate(image, left_x_map, left_y_map)
undistorted_right = interpolate(image, right_x_map, right_y_map)
cv2.imshow('Left Camera', undistorted_left)
cv2.imshow('Right Camera', undistorted_right)
if cv2.waitKey(1) & 0xFF == ord('q'):
break
def main():
controller = Leap.Controller()
controller.set_policy_flags(Leap.Controller.POLICY_IMAGES)
try:
process(controller)
except KeyboardInterrupt:
sys.exit(0)
if __name__ == '__main__':
main()
(edited to flip calibration map and remove erroneous image resize).
