After having received the dev kit from the Leap Motion team a while back, we enjoyed playing with the many demos, examples, and libraries posted by fellow Leap Motion developers. Many asked for linking with H/W including Android, Raspberry Pi, and Arduino. A few mustered the courage to get hardware rolling using the device. Some examples included the control of a Labyrinth maze using the Leap Motion Controller.
In another recent development, Xavier successfully interfaced the Leap Motion Controller and Arduino using the Node.js library. This was pretty cool, except for the fact that the Arduino had to be connected to the USB of the PC from which it was receiving data using the Firmata protocol. A rather unfortunate (or fortunate) thing is that I burned up two of my USB ports, leaving only one port working on my laptop – to which I had a choice of connecting either the Leap Motion Controller or the Arduino. So, in essence, we couldn’t try the above demo.
That set me thinking. Wouldn’t it be a lot cooler if we could use our laptop’s inbuilt Bluetooth module to send Leap Motion data wirelessly to a Bluetooth-enabled Arduino and have some fun? That idea, coupled with some intense coding, a boring Saturday, and some electric shocks resulted in this:
For those already familiar with Java, Eclipse, Leap Motion, and Bluetooth RXTX using Java, here’s the source code along with references and resources.
References
- Two-way communcation with the serial port
- RXTX for Java (DLLs for 64-bit machine)
- Interfacing Arduino and Java
- Leap Motion Java Example from SDK
Java code
package com.leaparduino.hello;
* Copyright (C) 2012-2013 Leap Motion, Inc. All rights reserved. *
* Leap Motion proprietary and confidential. Not for distribution. *
* Use subject to the terms of the Leap Motion SDK Agreement available at *
* https://www.leapmotiontechnology.com/sdk_agreement, or another agreement *
* between Leap Motion and you, your company or other organization. *
import gnu.io.CommPort;
import gnu.io.CommPortIdentifier;
import gnu.io.SerialPort;
import java.io.IOException;
import java.io.OutputStream;
import com.leapmotion.leap.Controller;
import com.leapmotion.leap.Frame;
import com.leapmotion.leap.Listener;
//import java.lang.Math;
class SampleListenerMain extends Listener {
public void onInit(Controller controller) {
System.out.println("Initialized");
public void onConnect(Controller controller) {
System.out.println("Connected");
public void onDisconnect(Controller controller) {
System.out.println("Disconnected");
public void onExit(Controller controller) {
System.out.println("Exited");
public void onFrame(Controller controller) {
Frame frame = controller.frame();
System.out.println(frame.fingers().count());
LeapIntoArduino.writeToArduino(frame.fingers().count());
try {
Thread.sleep(500);
} catch (InterruptedException e) {
// TODO Auto-generated catch block
e.printStackTrace();
class LeapIntoArduino {
static OutputStream out = null;
public static void main(String[] args) {
//Connect to Arduino BT
try
(new LeapIntoArduino()).connect("COM12");
catch ( Exception e )
System.exit(0);
// Create a sample listener and controller
SampleListenerMain listener = new SampleListenerMain();
Controller controller = new Controller();
// Have the sample listener receive events from the controller
controller.addListener(listener);
// Keep this process running until Enter is pressed
System.out.println("Press Enter to quit...");
try {
System.in.read();
} catch (IOException e) {
// Remove the sample listener when done
controller.removeListener(listener);
void connect ( String portName ) throws Exception {
CommPortIdentifier portIdentifier = CommPortIdentifier.getPortIdentifier(portName);
if ( portIdentifier.isCurrentlyOwned() )
System.out.println("Error: Port is currently in use");
else
CommPort commPort = portIdentifier.open(this.getClass().getName(),2000);
if ( commPort instanceof SerialPort )
SerialPort serialPort = (SerialPort) commPort;
serialPort.setSerialPortParams(9600,SerialPort.DATABITS_8,SerialPort.STOPBITS_1,
SerialPort.PARITY_NONE);
out = serialPort.getOutputStream();
else
System.out.println("Error: Only serial ports are handled by this example.");
public static void writeToArduino(int noOfFingers)
String tmpStr = Integer.toString(noOfFingers);;
byte bytes[] = tmpStr.getBytes();
try {
out.write(bytes);
} catch (IOException e) { }
Arduino code
#include <LiquidCrystal.h>
LiquidCrystal lcd(8,9,10,11,12,13);
char ch;
void setup()
Serial.begin(9600);
lcd.begin(16,2);
pinMode(2,OUTPUT);
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
digitalWrite(2,LOW);
digitalWrite(3,LOW);
digitalWrite(4,LOW);
void loop()
lcd.setCursor(0,0);
lcd.print("Remote Value:");
if (Serial.available()) {
lcd.setCursor(0,1);
ch = Serial.read();
lcd.print(ch);
if(ch == '1')
digitalWrite(2,HIGH);
if(ch == '2')
if(ch == '3')
digitalWrite(3,HIGH);
if(ch == '4')
if(ch == '5')
digitalWrite(4,HIGH);
if(ch == '6')
delay(50);
delay(10);
Quick notes
- The Bluetooth serial port in my Laptop was COM13, hence used that in the code. Please replace this with your COM PORT NO.
- The Arduino sketch includes code for LCD also. Since I didn’t have an extra serial port on Laptop to debug, I used this. This can be removed.
- The if conditions in Arduino can be replaced with well mannered if-else checks.
- Please use the right version of rxtxSerial.dll (32 / 64 bit) in your Java JRE’s bin.
- Make sure you have added the LeapJava.jar (and also the DLLs) and RXTXcomm.jar to the Eclipse project
The original version of this post appeared on Syed Anwaarullah’s website, where he writes about coding and hardware.
Pingback: Wireless gesture control of Arduino using LeapMotion and ESP8266 | .()
Pingback: Leap Motion Wirelessly Controlling a Prosthetic Hand With an Arduino | Hackaday()
Pingback: Leap Motion Wirelessly Controlling a Prosthetic Hand With an Arduino | Ad Pub()
Pingback: Making a Fist with the Raptor Hand()
