Hi folks,
We’re happy to share a beta preview of an upcoming release of the Leap Motion Software and Airspace Home, version 1.2.
The idea behind this preview is to give you a pre-release look at some of what we’ve been working on lately in the Leap Motion control software and Airspace Home. Note: this beta update does not include advances we are making to the core tracking (but we are also working on getting v2.0 ready to share as a beta with the broader developer community).
This is a beta preview build and will not be as stable as the final 1.2 release. In particular, we do not recommend you try this if you are using Leap Motion embedded inside a HP Envy 17 Leap Motion SE laptop PC or a HP Leap Motion keyboard (we’re still fixing some bugs).
Put simply: proceed with caution. This is not a final production build.
You can get the installer preview at: https://www.leapmotiontechnology.com/downloads/installer-preview
Features and bug fixes you may be interested in checking out:
- Airspace Home and Control Panel in 2 additional languages: Italian
and Korean
- Airspace labs: feature playground, starting with 1 experimental feature:
1) Sort your apps in Airspace Home based on the most recently used app
- Introducing Airspace Home notifications: In the top right, a small notification area to help users discover apps/features that have recently been added to Airspace Store and other potential updates about Leap Motion
- Numerous Airspace Home stability and performance improvements
- Out of box experience improvements, including fixing a crash experience in Orientation
- Feature in the control panel to allow for opting out of reporting usage
metrics
- Various installer fixes & uninstaller bugfixes
- Streamlined software updating mechanism
- Updated the control panel to Qt 5 UI
- Updated websockets protocol to v5
- Control panel and service stability fixes
- Reduced OS X package size by removing legacy 32-bit
- Fixed problems of the service losing communication with the control panel
- Socket security fix (use "websockets_allow_remote" config option for legacy behavior)
- Linux installer (last update was 1.09, so we’re glad to bring it back)
- Fixed installation on Debian
Note: On OS X, in rare cases, following installation control panel and service may not start. To resolve: install again. This will be resolved prior to production release.
If you install this and run into any issues, please let us know. In addition, if you’re looking to get back to a stable build, simply get the latest production software from: https://www.leapmotiontechnology.com/setup
We’re looking forward to your feedback.
Onwards,
-Dan
