Simple, import LM sdk, and read all the LM documentation if you want to have an idea otherwise you will get lost super soon.
you need to get the position of the palm so if you twist turns left/right pull/push will move forward backwards, if you just look at code you will still dont understand try to get position as text in the debuger for unity so you can see what each number means base on your hand position and work with that.
