From my understanding, eLeapDeviceStatus is a bitfield where 1 bit corresponds to 1 status, however I found this to not be the case.
The first couple statuses are fine, they correspond to 1, 2, 4, 8, and 16, but the last statues are huge numbers. For example, eleapDeviceStatus_BadControl is set to 3892379652, or in binary, 11101000000000010000000000000100. This causes a problem with overlapping bits 00000000000000000000000000000100 from the status eLeapDeviceStatus_Robust, which in binary is just 100 or in decimal 4.
How are we supposed to distinguish between these two fields if they share the 3rd bit? Or am I just reading the documentation wrong.
Thanks for any suggestions!
