This is Debian 9 Stretch? Unfortunately we haven't done any testing there, given the last time we did a Linux release was in the days of Debian 8 Wheezy,
Actually I am using Buster, which is even ahead of Stretch.
plus V2 only officially supported Ubuntu.
I know. I don't expect any support here, but I thought it might be interesting for you, and I am still happy about any help
If it still responds on the socket, you could also check whether it detects your device when plugged in. You can use either the systemctl log or the GUI log in LeapControlPanel.
I tried to start the leapd from commandline, and attach the LeapMotion. You where right, the LeapMotion is detected.
[Info] WebSocket server started
[Info] Secure WebSocket server started
[Info] Leap Motion Controller detected: LP43516768423
[Info] Firmware is up to date.
Failed to parse a message from a zero-copy input stream
However, using the Visualiser there is no signal shown. Usually the LeapMotion gets some red lights when connecting, which didn't happen. Stopping via Ctrl^C didn't work as well. The LeapControlPanel seem the recognise the Ctrl^C, as it claims that there is no daemon running any more.
Does your hang on exit happen even when there is no Leap Motion Controller connected to the machine?
That's how I discovered the bug. I had leapd running per default, together with the small linux uinput driver I wrote. Usually I hadn't connected any device. When I tried to shutdown the system leapd blocked the entire shutdown, till systemd finally decided to kill it using SIGKILL.
Hope that helps.
Best,
Andreas
