I got Leap Motion in 2013. I was very excited, played with it, bought some apps from Leap Motion's store or whatever it was called and forgot about it for a decade.
Recently I've decided to give Leap Motion a second chance.
Does Leap Motion properly work with Windows 11?
First of all I downloaded Gemini as official site recommended me. It worked fine, tracking was on, I saw myself and my hands. Then I wanted to try some apps from Gallery (https://www.leapmotiontechnology.com). Apps didn't want to work at all or to work properly, most of them displayed error "Allow Background Apps". After that I found a solution (I thought it was a solution): uninstall Gemini and use old SDK 2.3.1. OK, done. Now "Leap Motion Control Panel" displays "Controller if off" in Windows' tray although it is on and the green light shines. Troubleshooting section doesn't help. Leap Motion App Home displays endless "Connecting to authentication server...".
All I wanted is to control my Windows 11 with Leap Motion (for example, AeroTouch, Handwave, etc.). What else can I try now? Should I install Gemini again and try some other apps? Is Leap Motion a dead project?
