You can use this library on both web and AIR projects. If you are using it on an AIR for Desktop project, you can take advantage of the AIR Native Extension.
Download the ane-file and place it somewhere in your project (preferably in the directory where you would put your swc files). Link the ane file to your project:
Flash Builder 4.7
- Right click on your AIR for desktop project and choose properties.
- Select Actionscript build path > Library path and click on Add SWC… Select the ane file you just downloaded.
- In that same window, choose Native Extensions and click on Add ANE… Select that same ane file.
- Select Actionscript Build Packaging > Native extensions. Check the checkbox next to the native extension. Ignore the warning that says the extension isn't used.
Flash CC/Flash CS6
- Select File > Actionscript settings.
- On the Library Path tab, click on the "Browse to a Native Extension (ANE)" button (button to the right of the SWC button).
- Choose the ane file you just downloaded.
IntelliJ IDEA
- Right-click on your module and choose "Open Module Settings".
- Select the build configuration for your Module and open the Dependencies tab.
- Click on the plus (+) button on the bottom of that window and choose "New Library…".
Using the ANE on Windows
If you are using the ANE on Windows, you need to add the Leap Motion program folder to your PATH.
- From the Desktop, right-click My Computer and click Properties.
- Click Advanced System Settings link in the left column.
- In the System Properties window click the Environment Variables button.
- In the Environment Variables window, highlight the Path variable in the Systems Variable section and click the Edit button.
- Add the Leap Motion folder from your program files at the end of that line (ex: C:\Program Files (x86)\Leap Motion\Core Services).
Documentation
To generate documentation, simply run ant docs from the build/ directory.
Authors
Victor Norgren
Wouter Verweirder
Copyright and license
Copyright © 2013 logotype
Author: Victor Norgren
Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions: The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
0 Comments
