The Leap Motion software installed on any computer with a Leap Motion controller provides tracking data through a WebSocket server. The WebSocket server listens to port 6347 on the localhost domain (http://127.0.0.1:6437). Any client application, including Web clients, that can make a WebSocket connection can access the Leap Motion tracking data in the form of JSON-formatted messages. The WebSocket server is provided by the leapd process, which runs as a service on Windows and a daemon on OS X and Linux.
In most cases, you should use an existing client library rather than implement this protocol directly in an application. This article is provided to help you if you are developing your own library. Existing libraries include:
The communication between the WebSocket server and a client is mediated by a data exchange subprotocol. This subprotocol defines which messages can be sent between the client and the server and the format of the JSON data. The protocol version defines which feature set the server uses to communicate with a client.
You can request a specific version of the Leap Motion subprotocol by adding a string of the form v6.json to the WebSocket URL, where the digit, in this case 6 indicates which version to use. If you omit this part of the URL, you will get version 1. Note that the Leap Motion leap.js JavaScript library automatically selects the protocol version corresponding to the library version. When you successfully connect to the Leap Motion WebSocket server, it responds with a message reporting the protocol version. If the client’s Leap Motion software is out-of-date, then this version could be less than the one you requested.
The current version of the protocol is v6.json.
The WebSocket server and a client can exchange the following messages:
Server to client
version
Indicates the version numbers of the Leap Motion service and WebSocket subprotocol:
{"serviceVersion":"2.3.1+33747", "version":6}
deviceEvent
Sent when the Leap Motion when the service/daemon is paused or resumed and when the controller hardware is plugged in or unplugged:
{ "event": { "state": { "attached": false, "id": "NNNNNNNNNNN", "streaming": false, "type": "peripheral" }, "type": "deviceEvent" } }
id A string containing the ID of the Leap Mption device. attached Whether the hardware device is plugged in or attached. streaming Whether the service/daemon is sending tracking data. Always false if attached is false. type The hardware form factor. One of: “peripheral”, “keyboard”, “laptop”
- Tracking data
Contains a set of tracking data. See JSON tracking data format.
Client to server
Specifies whether the client wants to receive frames when it is not the focused application:
{"background": true}
{"background": false}
Specifies whether the application is active. Setting focused to true, stops other WebSocket clients from getting data. Setting focused to false stops your WebSocket client from getting data (and potentially unwanted input):
{"focused": true}
{"focused": false}
Enables or disables gesture recognition data:
{"enableGestures": true}
{"enableGestures": false}
Specifies whether the client application expects the Leap Motion hardware to be attached to a head-mounted display:
{"optimizeHMD": true}
{"optimizeHMD": false}
To send a message to the WebSocket server, first encode the desired message as a JSON string. In JavaScript, for example, you can use the JSON stringify() function and then send the message using the WebSocket send function:
//ws is a connected WebSocket object
var backgroundMessage = JSON.stringify({background: true});
ws.send(backgroundMessage);
Each frame of data from the WebSocket server contains JSON defining a frame. The attributes of a frame in the JSON message are similar, but not identical to those of a |Frame|_ object obtained through the native library. They include:
"currentFrameRate": float "id": float "r": array of floats (Matrix) "s": float "t": array of floats (vector) "timestamp": integer "devices": not implemented (always an empty array) "gestures": array of Gesture objects (Attributes vary by gesture type) "center": array of floats (vector) -- circle only "direction": array of floats (vector) -- swipe, keyTap, screenTap only "duration": integer microseconds "handIds": array of integers "id": integer "normal": array of floats -- circle only "pointableIds": array "position": array of floats (vector) -- swipe, keyTap, screenTap only "progress": float -- circle, keyTap, screenTap only "radius": float -- circle only "speed": float -- swipe only "startPosition": array of float (vector) -- swipe only "state": string - one of "start", "update", "stop" "type": string - one of "circle", "swipe", "keyTap", "screenTap" "hands": array of Hand objects "armBasis: the 3 basis vectors of the arm (array of vectors) "armWidth: float "confidence: float "direction": array of floats (vector) "elbow: array of floats (vector) "grabStrength: float "id": integer "palmNormal": array of floats (vector) "palmPosition": array of floats (vector) "palmVelocity": array of floats (vector) "pinchStrength: float "r": array of floats (Matrix) "s": float "sphereCenter": array of floats (vector) "sphereRadius": float "stabilizedPalmPosition": array of floats (vector) "t": array of floats (vector) "timeVisible": float "type": string - one of "right", "left" "wrist: array of floats (vector) "interactionBox": object "center": array of floats (vector) "size": array of floats (vector) "pointables": array of Pointable objects "bases": the 3 basis vectors for each bone, in index order, wrist to tip, (array of vectors). "btipPosition": the position of the tip of the distal phalanx as an array of 3 floats. "carpPosition": the position of the base of metacarpal bone as an array of 3 floats. "dipPosition:" the position of the base of the distal phalanx as an array of 3 floats. "direction": array of floats (vector) "extended": boolean (true or false) "handId": integer "id": integer "length": float "mcpPosition": a position vector as an array of 3 floating point numbers "pipPosition": a position vector as an array of 3 floating point numbers "stabilizedTipPosition": array of floats (vector) "timeVisible": float "tipPosition": array of floats (vector) "tipVelocity": array of floats (vector) "tool": boolean (true or false) "touchDistance": float "touchZone": string - one of "none", "hovering", "touching" "type": integer - 0 is thumb; 4 is pinky "width": float
Notes:
The motion factors, r, s, t, attached to Hand and |Frame| objects are snapshots of the motion occuring across frames. These factors must be combined with those of a previous frame to derive the relative motion.
The matrix expressing the relative rotation between two frames can be calculated by multiplying the r matrix from the current frame by the inverse of the r matrix of the starting frame.
The relative scale factor between two frames can be calculated by subtracting the s value from the starting frame from the current s value and computing the natural exponential function of the result.
The relative translation factor between two frames can be calculated by subtracting the t vector from the starting frame from the current t vector.
This document describes the most recent version of the protocol.
Each version of the protocol corresponds to particular versions of the Leap Motion software installed on a client computer as well as a versions of the leap.js library which use the protocol:
| Protocol | Leap Motion Client Software | Leap.js |
| v1.json | prerelease | 0.1.n |
| v2.json | prerelease | 0.2.n |
| v3.json | 1.0+ | 0.3.n |
| v4.json | 1.0.9+ | 0.4.n |
| v5.json | 1.2.0+ | 0.5.n |
| v6.json | 2.0+ | 0.6.n |
The following changes were made from previous versions of the protocol:
