Documentation
Tracking Hands, Fingers, and Tools
Hands, fingers, and tools are the basic entities tracked by the Leap Motion system. This article discusses the details of gettting and using the objects representing these entities.
Overview
The Leap API defines a class representing each of the basic tracked objects.
The Frame object provides access to lists of hands, fingers, and tools. Fingers and tools are examples of pointable objects and can be treated together using the PointableList or separately using the FingerList and ToolList classes. Hand objects provide access to their fingers and tools (both together in a PointableList or separately).
The physical characteristics of hands, fingers, and tools are reported in reference to the Leap coordinate system (measured in units of millimeters). The Leap SDK provides a Vector class to describe points and directions. The Vector class provides several useful math functions for working with vectors.
Hand, and Pointable Lists
The list classes all have a similar structure. They are designed to act like vector-style arrays and support iterators. You cannot remove or alter the member objects of lists received from the Leap API, but you can combine lists of the same object type.
To use an iterator with one of these lists:
    for(HandList::const_iterator hl = handList.begin(); hl != handList.end();)
                std::cout << *hl << std::endl;
The Hand, Pointable, Finger, and Tool lists define additional functions for getting members of the list based on their relative position within the Leap coordinate system. These functions include leftmost(), rightmost(), and frontmost(). The following snippet illustrates a few ways to use these functions:
    Leap::Finger farLeft = frame.fingers().leftmost();
    Leap::Finger mostForwardOnHand = frame.hands()[0].fingers().frontmost();
    Leap::Tool rightTool = frame.tools().rightmost();
A more complex example calculates the walls of a bounding box containing all detected pointable objects. This example defines its own functions for getting the top, bottom, and rear pointables since these are not included in the API:
    float left = frame.pointables().leftmost().tipPosition().x;
    float right = frame.pointables().rightmost().tipPosition().x;
    float front = frame.pointables().frontmost().tipPosition().z;
    float back = backmost(frame.pointables()).tipPosition().z;
    float top = topmost(frame.pointables()).tipPosition().y;
    float bottom = bottommost(frame.pointables()).tipPosition().y;
    Leap::Pointable backmost(PointableList pointables)
        if(pointables.count() == 0) return Leap::Pointable::invalid();
        Leap::Pointable backmost = pointables[0];
        for( int p = 1; p < pointables.count(); p++ )
            if( pointables[p].tipPosition().z > backmost.tipPosition().z)
                backmost = pointables[p];
        return backmost;
    Leap::Pointable topmost(PointableList pointables)
        Leap::Pointable topmost = pointables[0];
            if( pointables[p].tipPosition().y > topmost.tipPosition().y)
                topmost = pointables[p];
        return topmost;
    Leap::Pointable bottommost(PointableList pointables)
        Leap::Pointable bottommost = pointables[0];
            if( pointables[p].tipPosition().y < bottommost.tipPosition().y )
                bottommost = pointables[p];
        return bottommost;
Hands
The Hand class represents a physical hand detected by the Leap. A Hand object provides access to lists of its pointables as well as attributes describing the hand position, orientation, and movement. Get Hand objects from a Frame:
    Leap::Frame frame = controller.frame(); // controller is a Leap::Controller object
    Leap::HandList hands = frame.hands();
    Leap::Hand firstHand = hands[0];
Or, if you know the ID from a previous frame:
   Leap::Hand knownHand = frame.hand(handID);
You can also get hands by their relative positions in the frame:
    Leap::Hand leftmost = hands.leftmost();
    Leap::Hand rightmost = hands.rightmost();
    Leap::Hand frontmost = hands.frontmost();
Note that the the leftmost() and rightmost() functions only identify which hand is farthest to the left or right. The functions do not identify which hand is the right or left hand.
Getting the Hand Characteristics
A hand is described by its position, orientation, and motion.
The hand's position is given by its palm position attribute, which provides a vector containing the 3-dimensional coordinates of the palm center point in millimeters from the Leap Motion origin. The hand's orientation is given by two vectors: the direction, which points from the palm center towards the fingers, and the palm normal, which points out of the palm, perpendicular to the plane of the hand.
The movement of the hand is given by the velocity attribute, which is a vector providing the instantaneous motion of the hand in mm/s. You can also get motion factors that translate how a hand has moved between two given frames into translation, rotation, and scaling values.
The following code snippet illustrates how to get a Hand object from a frame and access its basic attributes:
    Leap::Hand hand = frame.hands().rightmost();
    Leap::Vector position = hand.palmPosition();
    Leap::Vector velocity = hand.palmVelocity();
    Leap::Vector direction = hand.direction();
Getting the Fingers and Tools
You can get the fingers and tools associated with a hand as a list or individually using an ID obtained in a previous frame.
By list:
    // hand is a Leap::Hand object
    Leap::PointableList pointables = hand.pointables(); // Both fingers and tools
    Leap::FingerList fingers = hand.fingers();
    Leap::ToolList tools = hand.tools();
By ID from a previous frame:
    Leap::Pointable knownPointable = hand.pointable(pointableID);
To get a finger or tool by relative position within the Leap field of view, use the right-, left- and frontmost functions of the matching list class:
    Leap::Pointable leftPointable = hand.pointables().leftmost();
    Leap::Finger rightFinger = hand.fingers().rightmost();
    Leap::Tool frontTool = hand.tools().frontmost();
Note that these functions are relative to the Leap Motion origin, not to the hand itself. To get the fingers relative to the hand, you can use the Leap Matrix class to transform the finger positions into the hands frame of reference.
Computing the Hand Orientation
You can compute the hand orientation angles using the Hand direction and normal vectors. The Vector class defines functions for getting the pitch (angle around the x-axis), yaw (angle around the y-axis), and roll (angle around the z-axis):
    float pitch = hand.direction().pitch();
    float yaw = hand.direction().yaw();
    float roll = hand.palmNormal().roll();
Note that the roll function only provides the expected angle when used with a normal vector.
Transforming Finger Coordinates into the Hand's Frame of Reference
Sometimes it is useful to obtain the coordinates of the fingers of a hand with respect to the hand's frame of reference. This lets you sort the fingers spatially and can simplify analysis of finger positions. You can create a transform matrix using the Leap Matrix class to transform the finger position and direction coordinates. The hand frame of reference can be usefully defined with the hand's direction and palm normal vectors, with the third axis defined by the cross product between the two. This puts the x-axis sideways across the hand, the z-axis pointing forward, and the y-axis parallel with the palm normal.
    Leap::Frame frame = leap.frame();
    for( int h = 0; h < frame.hands().count(); h++ )
        Leap::Hand leapHand = frame.hands()[h];
        Leap::Vector handXBasis =  leapHand.palmNormal().cross(leapHand.direction()).normalized();
        Leap::Vector handYBasis = -leapHand.palmNormal();
        Leap::Vector handZBasis = -leapHand.direction();
        Leap::Vector handOrigin =  leapHand.palmPosition();
        Leap::Matrix handTransform = Leap::Matrix(handXBasis, handYBasis, handZBasis, handOrigin);
        handTransform = handTransform.rigidInverse();
        for( int f = 0; f < leapHand.fingers().count(); f++ )
            Leap::Finger leapFinger = leapHand.fingers()[f];
            Leap::Vector transformedPosition = handTransform.transformPoint(leapFinger.tipPosition());
            Leap::Vector transformedDirection = handTransform.transformDirection(leapFinger.direction());
            // Do something with the transformed fingers
Pointables
Pointable objects represent fingers and tools — i.e. things that can be pointed. You can get the fingers and tools associated with a particular hand from the Hand object. You can also get all detected pointables from a Frame object. Pointables are not necessarily associated with a Hand object — the physical hand itself may be out of the field of view or blocked by another hand. Thus the list of pointables from the frame can include fingers and tools not found in any list associated with a hand.
Pointable objects have many attributes describing the characteristics of the represented finger or tool:
  • Tip position — the instantaneous position in mm from the Leap Motion origin.
  • Tip velocity — the instantaneous velocity in mm/s.
  • Stabilized tip position — the position filtered and stabilized using velocity and past positions.
  • Direction — the current pointing direction vector.
  • Length — the apparent length of the finger or tool.
  • Width — the average width.
  • Touch distance — the normalized distance from the virtual touch plane.
  • Touch zone — the pointable's current relation to the virtual touch plane.
The following example illustrates how to get a pointable object from a frame and access its basic characteristics:
    Leap::Pointable pointable = frame.pointables().frontmost();
    Leap::Vector direction = pointable.direction();
    float length = pointable.length();
    float width = pointable.width();
    Leap::Vector stabilizedPosition = pointable.stabilizedTipPosition();
    Leap::Vector position = pointable.tipPosition();
    Leap::Vector speed = pointable.tipVelocity();
    float touchDistance = pointable.touchDistance();
    Leap::Pointable::Zone zone = pointable.touchZone();
Converting a Pointable Object to a Finger or Tool
To convert a Pointable object to its proper Finger or Tool subclass, use the appropriate Finger or Tool constructor (one of the few times that you should use the constructor for a Leap class).
    if (pointable.isTool()) {
        Leap::Tool tool = Leap::Tool(pointable);
        Leap::Finger finger = Leap::Finger(pointable);
Calculating the Position of the Base of a Finger
If you need to calculate the position of the base of the finger, you can use the finger tip position and direction as follows:
    Leap::Vector basePosition = -pointable.direction() * pointable.length();
    basePosition += pointable.tipPosition();
